kingswood country
- Sep 5, 2011
- 1,092
- 3
- 38
- Location
- Melton
- hj kingswood
Well the vac gauge is reading about 15.5" and it's pretty stable.
As said, I believe the float level is correct, it's only just moistening below the sight hole,
and just sitting in the garage it's fine.
hold the revs up for a little while and it's starts dropping the idle and the vac gauge starts flickering a couple of inch
The same as it usually does before it starts doing what it's doing.
On aussie v8s forum, they've also said to take the fuel bowl of and blow it all out and refit, will gasket cement work on putting it back together? Or will I need gaskets?
