Reuben Campbell
- Aug 20, 2019
- 45
- 19
- 8
- Age
- 43
- Location
- Coondle
- VT Wagon, 69 dat 1000(delco powered)
Hi Folks
Car is VT 2001 Executive wagon 3.8l , 340km - and showing every km on it - its hard a hard life I think before it came to me in 2016.
The engine is very tired, but performs just fine for its intended purpose.
The car is just a hack , but it still deserves some basic maintenance. It wasn't supposed to last thins long, but it wont die.
For the last 12 months, its been having this half misfire / hesitation thing going on when the car is under light acceleration, in 4th, with light load, like going up a hill.
It seems to only occur once its at operating temp, and gets worse in hot weather. Dropping it into 3rd would fix it.
Recently, it seems to be doing its hesitation trick now when in 3rd and medium acceleration.
Its also having trouble idling smoothly. It will sit fine for about 20-30 seconds, then just die and pick itself back up again without stalling.
I'm guessing both are related somewhere in the ignition system or a sensor.
From my reading i thought it was a coil or the plate under the coils (DFI unit?). I found some youtube videos on testing them, and they all tested within spec.
None the less, I swapped out the DFI unit and coils from a spare I had in the shed - no change.
Now the the coils and DFI came from a VXII so they could be just as buggered.
Before I start on just replacing every part on the engine, is there a good order i should start on?
is the ebay stuff any good? It all seems pretty cheap, so its in the right price range for the purpose of the car, but there is no point if they are unreliable or just going to fail in 6 months.
I'm thinking
coils
DFi plate
plug leads
CAS sensor (the rough idle?)
to start with.
Does anyone else have a better plan / opinion?
Thanks in advance
I'm thinking
coils
DFi plate
plug leads
to start with.
Thanks in advance
