Reuben Campbell
- Aug 20, 2019
- 45
- 19
- 8
- Age
- 43
- Location
- Coondle
- VT Wagon, 69 dat 1000(delco powered)
so sprayed brake cleaner around anything i could get to - No changes that i could find, but i wasn't expecting anything as its idling fine.
Slow ,controlled acceleration everything seems to be fine.
Only when you give it a foot-full does it do its miss thing.
rechecked the coils - they seem to be fine.
Could be an injector, but then if it was failing, then it should be missing all the time, especially at high revs, which they do not.
Going to glue up the plenum to the runners this morning - just have to do some window repairs on the house first...
Glued up the plenum to runners face with No3 (non-hardening) aviation gasket glue - no change. - man that shiz is messy.
its still doing the drop in revs at idle every so often. I'm still suspecting a vacuum leak somewhere, but I'm running out of things to check. All the hose seem intact, and plugging into the ports. I've replaced the hose from the intake to the throttle body as that had cracked, but no change.
Could a intermittent sticking lifter be the cause?
This time of year, it almost never does it as the oil is already warm. During last winter, it would stick for about 60 seconds, then free up fine.
Ill see if I can pick up a Throttle position sensor today and fit that.
Ill also order an injector rebuild kit online - as it seems all the local stores cant/wont stock them in the state, so its going to take a week anyways.
