Glaze
Parts on the wayWell changed coil or swapped ignition module with known working unit yet?
Red light is off once key is turned to “on” or whenever I press the unlock button on the remote however just as I turn the key to fire it it flashes briefly but never comes back on. Every time I start the car the immobiliser light just flashes once while the car is cranking but it never comes back on then it rearms as per normal. Maybe a bad read from the key considering it is held by a zip tie.Check to see if the flashing red light on the dash goes out before trying to start it.
Just tried again, when I go to start it the immobiliser light flashes brieflyif the light turns off the key is working.
That's fine as that's just the voltage dropping when the starter is engaged. As long as it turns off.Just tried again, when I go to start it the immobiliser light flashes briefly
Yeah it turns off while cranking but when key is turned to run position it flashes briefly... well bought a new key and same thing immobiliser light flashes once when turning to run position. Gonna change the coil tomorrow and see what happens then maybe the moduleThat's fine as that's just the voltage dropping when the starter is engaged. As long as it turns off.
