Nut Kracker
Donating Member
- Oct 18, 2012
- 4,760
- 150
- 63
- Age
- 64
- Location
- Echuca Vic.
- VT SS 304ci (195i)
Hi all.
Sorry if this is a bit long winded, but the more information I give you, the more I hope to get back.
What I am wondering is. How much (if any) is the engine timing effected by how much the engine has been modified?
As some of you may be aware my engine (VT 304ci) has been modified.
Modifications are......
MAF less tune.
Custom high rise intake manifold & OTR.
Twin 63mm T/B.
Heads ported & polished.
Roller rockers.
Double valve springs.
Extractors 2 1/2 cat back.
Crane 888241 Hydraulic Roller Cam.
Specifications......
Series and grind number. Components.......HR-226/345-2S-10
Deg. @ .050” Cam Lift Int./Exh....226/230
Deg. Adv. Dur. Int. Exh..............288/292
Deg. Lobe Separation.................110
Open/Close @ .050” Cam Lift Int./Exh........8 38 50 0
Lash Hot Int./Exh............. .000 .000
Gross Lift Int. Exh.............. .552 .563
What I'm trying to say is.
With my engine, would the factory timing (12 Degrees BTDC) be suitable.
I had the timing re set a little while ago @ factory 12 BTDC, as the dizzy became loose and it was popping and farting all over
the place.
I don't know what it was set at, at the time of the modifications and I can't get in touch with the engine builder to ask him.
It just seems to me, that up to around 60Kph and just going through the gears normally, it seems to be ever so slightly hesitating
and there is the occasional little "pop" out the exhaust, if there is not enough accelerator given, when changing up through 2nd to 3rd.
But drop it back a cog or two, give it a little bit and it pushes you back in the seat.
I realise the cam kicks in at around 2800 (and boy, does it ever), but it's just the lower end of the revs I am wondering about.
There wasn't any hesitation before the timing went south on me.
It does have a fairly lumpy idle and the base idle sits at around 950 to 1000 rpm.
Everything else checks out.
No DTC's set.
Ignition parts, IE. dizzy, coil, module etc. all check out ok.
Leads, spark plugs, replaced 6 months ago.
No vacuum leaks.
Injectors all good. As is fuel pressure.
All the 3 letter sensors and the O2's replaced 6 months ago.
Battery, alternator etc. all good.
Any opinions greatly appreciated.
NK.
MAF less tune.
Twin 63mm T/B.
Roller rockers.
the place.
No DTC's set.
No vacuum leaks.
NK.
