shane_3800
- Aug 13, 2011
- 4,223
- 1,798
- 113
- Age
- 35
- Location
- places
- vr commo
Man I'd rather start with iron block or atleast larger 6.0/6.2 alloy motor...more cubes easier power as in get more you want in much tamer combination.
Also if get defected or break motor still got original ls1 to put back in BUT also leave in car to drive/enjoy however long it takes to build big motor...probably 18 months.
Do like 5.7 but more aftermarket support for bigger engines & heads although engineering might be easier if start with iron 4.8/5.3.
Lots to think about & plan not to mention unpredictable delays that will drive ya crazy
On gum tree there's 40 5.3s comming in on a container.
They're taking deposits and a 5.3 with heads is $3300 suits rebuild.
That's a perfect start point imo.
Edit: The 5.3 from what I've seen can take a 4 inch stroke and has a 3.780" bore standard and you can bore it to 3.9". This will only give you 383 though unless you sleeve.
But if you can find one you can get 400ci out of a 6.0l block.
