bowmanj
- Jan 3, 2024
- 7
- 5
- 3
- Age
- 33
- Location
- Perth
- VE Omega Sedan 3.0L 2010
Hi,
I know there's a lot of these on here and I've read a fair few of them. I have a similar issue with my 2010 3.0L Omega Sedan and I would like to see if anybody has any ideas before I thrown more money at the problem. The vehicle was having issue with the Brakes being soft so early last year I took it in and they told me it needs a new brake Master Cylinder and Brake Booster which I paid for. After that I was having stability error come up occasionally on my LCD so I took it back in and they told me it was a faulty Brake Light switch so they replaced that. After this the car went back in several time where they had to re install a new brake light switch as the one they installed was "faulty" and they also had to replace the master cylinder they installed as that too was "faulty". Since then I have returned the car too them because the stability error still comes on, now every time I start the car and also my cruise control doesn't work (as in it turns on but it wont 'set' the speed). They've knocked me back and told me it is nothing they have done and that they can not figure out what is wrong and I need to take it into an Auto Sparky.
The only reason I am now reluctant to send it into an Auto sparky is that the car is getting older (190000kms) and I don't want to spend more money only to have the problems not get solved or lead to further problems. I'm posting this to see if these are events other VE owners have experienced and solved. I've diagnosed some of the issue myself, It seems that if I slightly press down of the brake pedal (I'm talking very slight 1-2cm) the brake lights don't turn on but also the cruise control can set and hold a speed as long as I have that slight pressure on it (if I press it down any more it operates as normal ie Brakes engage, lights come on cruise control disengages). So it seems like the vehicle is not getting the correct feedback about my wheel speed whilst the brake pedal is not engaged which could be the cause of the issues. I thought this could be the ABS at fault, I bought a second hand module (I don't feel confident replacing the pump) and the car still operated as it did before but now with the ABS light on (I assume due to the module not being coded in). Now I am thinking it could be the ABS pump that needs to be replaced. I'm happy to have someone do this but before I do has anybody else experienced similar issues as me and if so what was the solution?
Thanks,
Thanks,
