BlackVXGTS
- Aug 14, 2004
- 5,512
- 2,522
- 113
- Location
- Melbourne, SE
- GEN-F2 GTS A6, VS Clubsport 185 A4
Just to clarify, from 4L60e transmission common problems, your transmission problem is as below:
21. No movement in any gear: pump failure, or total loss of fluid. Remove & Repair/Replace, or refill pan and find the leak. If out of fluid, avoid running the engine until the trans is refilled to avoid pump damage. To check for pump failure, check fluid level with the engine off, then start the engine and recheck fluid level. If level does not go down when engine is running, the pump is broken.
That doesn't help you with finding transport for the car to Adelaide.
