After lots of thought and ringing around performance shops in Perth I have decided to get a few things done to rectify this lifter rattle in my L98, first thing was to try PI4ATES method he suggested which was to put some high zinc 10w40 engine oil to see if it would help, it did but only to a certain degree. Also the oil which I replaced was sent away for viscosity check to see if any metal shavings where apparent and yes there was, which basically meant the cam needed replacing,this is where the camshaft has shown signs of wear from the metal to metal contact. It can go from bad to worse when the roller wears enough to split in half and leave the now roller-less lifter to dig into the camshaft, this is where the noise goes from chatty parrot to an even worse sound and the repair bill may go from a couple of thousand to a whole new engine according to the shop.
So now have it booked in for a VCM-21 camshaft, Lunati dual valve springs, retainers, locks, chromoly pushrods, upgraded 3 bolt cam sprocket with ARP cam bolts, water pump and timing cover gaskets. Next I will be changing out the lifters for Morel Tie Bar Lifters, MLS Head Gaskets and ARP head bolts. Then its in for a VCM OTR and tune, all up Im looking at 5K. I could go for just the Morel Tie Bar lifters if the head gaskets and ARP head bolts aren't extremely necessary and save around 1k but am not sure if anyone can enlighten me that would be great.
The only issue I face atm is having stock heads and cats as well as stock exhaust I would have liked to go the normal route ie full exhaust system otr then cam but I just don't have the cash to do the whole lot in one go I know I am not going to draw anywhere near the power from the stock headers and exhaust after the cam install but that will be on the cards in the next few months. I read that changing the oil pump should be done along with a cam install should I add this to the list?
Any advice before I bite the bullet would be appreciated.
P.S. thnx PI4ATE for ur help so far mate.
