anyone with ls1 cam knowledge
HSV99
VT S2 HSV SV99
Yeah m8, no probs. If it's an auto it'd be alot better with a stally.
Hesko
VY SV8
Will probably need a better Air intake system and a torque converter if auto. Would go 114 lobe angle if auto and 112 if manual. But yeah sort out the Intake system first. Not expensive
HSV99
VT S2 HSV SV99
Nothing wrong with 112 LSA for an auto!!!
SIG-054
Y-Series Senator Signature
no need for a double row timing chain either, unless you really want to.
VTPREDATOR
35
Warwick
VE SS SPORTSWAGON
thort why i had the timing cover off, i might as well....
thanks guys, got me settled on it now.
VTPREDATOR
35
Warwick
VE SS SPORTSWAGON
whats the minimum stally i should be running?
troytroy2
YII Clubsport R8
it will work but the piss weak lift will cost u power. get a cam with the more agressive lobes. i think comp do the same cam with .581 lift. that will be a lot better.
+1 as above. More lift required to get more gain. Go XER lobes but will require double valve springs.
Have a look through TEXAS SPEED, you can pick up one of these Cams for $465 AUD plus postage - get springs and pushrods and the savings get better and the postage more efficient.
Sorry can't comment on the stally...
