V
vt2vygts
Guest
plum back is legal... venting isn't... i wish it were though
Thats what I was thinking I have seen setups using the factor airbox, just with some extra ducting for more air flow.bextor84 said:You have to use a pod??
the guy doing my turbo setup wants it that way. Since he's doing it cheap, i'll let it go.AirStrike said:Thats what I was thinking I have seen setups using the factor airbox, just with some extra ducting for more air flow.
AirStrike :air:
the turbo isn't actually fitted yet, and the problem i have is the turbo is so big, the only place to put it is where the factory airbox goesbextor84 said:Plumb back isn't illegal. You could always change your setup back to the factory airbox if you wanted stealthy, its just running a new pipe.
emmisions tests to get my setup 'legal' are over $6000 or soemthing, so the pod is going to be the last of my worries!EcotecManiac said:GFB actually make a switchable bov....you can have it plumb-back ready and switch it to vent to atmosphere by turning the top of the valve to change the position of the outlet. by the way stealth, are you going to make a shroud for the pod filter? if not, thats another defect right there. unless youre putting it down in the bumper.
