hi Bowen. if i left the water injector at 45psi wich is fuel line pressure, it would be 1/7th of the fuel to water ratio. we need it to be 1/10. so i will either be buying a pump with a suitable adjustable pressure in the range of 10-30psi or a pressure regulator. i assuming i line pressure of about 20psi instead of 45 psi would reduce the ration from 14.4% down to about 10% (THIS IS JUST A GUESS TESTING NEEDS TO BE DONE).
the injector is located at the start of the 90 degree bend leading to the T/B, and the injector is facing directly toward the T/B. the average injector has a resistance of 11.8 to 13 ohms, by wiring the second injector in parallel with injector number 1 the resistance of the circuit drops to 6 ohms. to resolve this a 5.6ohm 5w resistor is placed on the wiring leading toward injector 1. this resistor has to be closer to the ecu than the parallel wires running to the water injector, otherwise the resistance will be something like 8.5ohms. the negative wire runs to a switch located on the T/B to cut the circuit at less than 5% throttle. the wire then travels to a cabin master on/off and back to the negative terminal of the water injector.
a suitable pump (probably a fuel pump) and tank are placed in the boot (10L is my goal). the power for this is boosted from my subwoofer wiring. this pump also has a master on of switch in the cabin.
so far i'm a bit over halfway. i just need to buy a pump and a pressure regulator, if i cant find a suitable pump. find a suitable tank to place in the boot, with a hose running to the engine bay (im not sure if i will be running this hose through the cab or under car).
when i'm done i will make a proper detailed write-up, with photos and a wiring diagram. in total it will cost me $30-$60, but i already had a injector.
EDIT - notice up the top i said 1/7th not 1:7 the ratio would be 1:6 if it is 1/7th. also i didnt use a purge line as i had trouble with vacuum, and i want a better system than just vacuum. this way once i set the right line pressure i can maintain 10% water to fuel ratio right the way through my rev range no matter how much accelerator i'm using. i can turn the system on when the car is warm, and off a k or so before home to ensure there is no water left. i can also mount the tank in the boot out of the engine bay.
