ari666
250,000 hits
- Mar 10, 2009
- 11,835
- 128
- 63
- Location
- melbourne
- 1966 impala, R32 GTR
what youre doing is significantly dropping the wattage able to be drawn on that circuit, which means your injector wont be getting the same amount of "oomph" as the rest.
i mean i may be totally wrong, but in my mind, by reducing the current to that injector, youre basically making is Ms-response time far higher than the others, which will be making that cylinder run leaner, simply because the solenoid isnt getting saturated with enough wattage to pull it open. it may not be noticable at idle, but at higher RPM i daresay youll start getting some dodgie O2 readings on that bank, and thus, negating any positive results from the water injection.
if you wrap a wire around a spark plug lead, it can be used as an effective "inductance coil" (similar to your timing light) the current passing along the spark plug lead through the coil generates an electromagnet field which can then be used to trigger the injector. i know youre not really interested in the idea, so i wont bother making a circuit diagram.
where this idea falls down though is the fact that its just an on/off pulse signal, and is not controllable like the Ms-response your injectors are undergoing. itll just mean that injector#7 squirts when sparkplug 1 fires. the amount of time it squirts is anyones guess. but again, it can be measured out simply by looking at the amount of water used vs fuel and adjusting the water pressure to the injector accordingly.
but whatevs. im sure your way will be fine.
