Handy Andy
- Mar 26, 2018
- 6
- 5
- 3
- Age
- 70
- Location
- NSW
- VF SV6 Commodore
I have a 2014 VF SV6, last September my wife had an argument with a kangaroo that resulted in about $8k in damages. Most of the damage was on the front right hand headlight area.
We finally got the car back in mid January. The job the smash repair place did on the car was excellent, it looked fantastic when we picked it up. They did have problems with the front parking sensors, the end result was they had to replace all 4 sensors as per the VIN. The car was taken to the local Holden dealer as it was found that the Parking Assist Control Module had failed, a new PACM was installed and reset using their computer. The other day I when I was hooking a trailer to the car I found that none of the trailer lights worked, in fact the car didn't even recognise that the plug was connected. A couple of phone calls and visits later I was informed that the BCM and PACM do not need to be told that there is a Trailer Control Module (TCM) installed. The car is fitted with a HD towbar and I normally drive around with the tow extension removed, But I noticed that with the extension now installed the rear sensors go off when in reverse, I have gone into the Config on the radio and set it that there is a towbar fitted but it hasn't made any difference.
Initially I had a look around the battery area as years ago I had installed the TCM and a Redarc Brake Controller near the battery. I was surprised to find the main power wire for the Brake Controller had been disconnected from the circuit breaker and thought maybe this was the problem. Unfortunately after re-connecting it the problem wasn't solved.
Sorry about the long post but my real question is , does the BCM or maybe the PACM need to be informed that there is a TCM connected?
Regards
Handy Andy
Regards
Handy Andy
