You need to go through the following process. Note that it requires a Tech2 (or equivalent).
Programming Extra Keys to the Vehicle. Programming more keys for the vehicle can be achieved using TECH2
once the ESS has been re-linked to the vehicle as described as follows:
1. Ensure driver's door is closed, driver's door is unlocked, and wash-wipe switch is off.
2. Place new key into the ignition barrel.
3. Turn ignition on. Verify ESS beeps 5 times.
4. TECH2 must be operating in the “Normal Mode” submenu of the Body Control Module sub-menu.
5. Perform the Link Enable Procedure (see Section 6.5). Wait 1 second between each lock unlock to ensure the
door lock actuators function correctly during this procedure.
6. Verify that the ESS beeps twice. TECH2 reports ignition is at 12Vdc. The ESS has now entered “Key
Programming mode”.
7. Select Key Programming function – “Extra Key” - from the security sub-menu in the body menu of the TECH2.
When TECH2 requests ignition to be cycled with the existing key, leave the new key in the ignition barrel and
instead, press the unlock button on the existing key. Verify the ESS beeps once and the Theft Deterrent LED
stops flashing. Complete key programming as requested by TECH2.
8. Turn ignition off and wait for 2 seconds.
9. Turn ignition on. Verify ESS beeps once. The ESS is now operating in “normal mode”.
10. Crank engine. Verify vehicle starts as normal.
6.5 LINK ENABLE PROCEDURE.
Each ESS has it’s own unique Link Enable Code (LEC), programmed into each ESS by HSV. This code
corresponds to a unique sequence of 10 vehicle body functions comprising of the following actions:
1. Drivers door. Open then Close
2. Drivers door. Lock then Unlock
3. Wash-Wipe. On then off.
Approximately 60,000 link enable codes are available. (Pull stalk towards steering wheel and release).
For the Link Enable Procedure contact:
Australian Arrow Pty Ltd
Customer Service quoting ESS PIN.
Telephone: (03) 9785 0792
Facsimile: (03) 9775 0954
