I just bought a stock vt v6 for my first car and was just looking for ideas on what mods i should start with? any ideas would be appreciated! Thanks
An engine is basically just a big, fat, ugly air pump. It sucks it in, then pushes it out. Working on that principle, then the more air you can shove in it the better.
For the Forced Induction route they use a compressor of some sort (ie turbocharger, PD supercharger, centrifiugal supercharger) to push compressed air into the chambers. Naturally Aspirated is about using the suction of the engine itself to bring in more air, and the bigger the displacement the bigger bang.
Your first step is to get more air into the engine by way of a cold air intake and some high ratio rockers. The CAI is pretty basic, it's supposed to allow less restriction in the intake system (many people have different opinions of these, but its better to have and not need then blah blah blah). The high ratio rockers are little more tricky. They effectively increase the valve lift to draw more air into the chambers. Pretty much a noiseless camshaft upgrade. MACE also do the spacers, which are also pretty good.
2nd would be an exhaust system to get rid of the exhaust burnt gasses. A simple 2.5" catback would work well enough, but later down they track you might want to change the single cat to a dual and get some headers (But the gains v dollars is ****)
That'll all cost $2,000ish and get you around 130-140rwkw.
