KernowCrispy
- Apr 2, 2023
- 3
- 5
- 3
- Age
- 50
- Location
- Warrnambool, VIC
- 2009 SV6 Sportwagon in Voodoo Blue
Morning all!
Yesterday I finally got around to upgrading my SV6 brakes with the slightly larger V8 versions. In practice this means slightly larger rotors, new pads, braided lines and the same calipers held by the larger V8 brackets sourced from eBay.
All went well until I bled the brakes and I discovered one caliper was locking on, the front right.
After a great deal of f**king about I believe the problem has to do with the slide pins grabbing in the bracket. When the piston is withdrawn slightly (or pads removed) the caliper moves freely on the new pins. These were lightly greased according to the supplier’s instructions but I also tried the old pins which made no difference.
If I leave the pins even slightly loose then the caliper works fine. When I nip them up they jam up. I’ve tried rotating the pins in 30deg increments but no variation at all in behaviour.
I have ruled out the caliper being bent by using my original so it can only be the bracket. Right?
It doesn’t look bent. It did come from eBay wrecker but looked undamaged and just a bit dirty.
Does anyone have any advice or suggestions??
