Why on earth do they cut the shim off halfway up the piston!
So the OEM pads are Ferodo?Comparison photos of factory OEM vs Brembo…
They must be a lot harder than the rotors, as my rotors are 'worn to limits', but the pads have plenty of life left...
I noticed the rear brembo ceramic pads and a few other brands have what appears to be anti squeal shims attached. Is everyone still putting the holden ones in as well when using pads with shims attached or leaving them out?
Thanks for the info.If the replacement pads have shims, I use those. If not, I’d reuse the existing ones (if they are detachable).
I also use ‘brake grease’ as well to help prevent squealing.
So, um, what is the need for the counter weights? Surely they wouldn't be there if no use
