J_D 2.0
- Mar 20, 2020
- 2,965
- 6,996
- 113
- Location
- Ipswich
- 2009 VE SSV M6 on LPG and 2022 Kawasaki Z650L
Everyone says upgrade brakes on more powerful cars but the majority of the time it’s not actually required. You won’t be able to stop any sooner with upgraded brakes in initial application as both stock brakes and upgraded brakes will lock up at maximum application (if you don’t have ABS) so the limit is actually the tyres.The only car I've ever had boil on me was my old VP wagon with about 0.5mm of pad left and rotors on min thickness with rusty brake fluid.
I'm the opposite of above. Build engine and when stuff brakes then upgrade.
You go the other way you might spend 2k on a diff then do the engine and shear an axle only to be told bigger better axles need a new diff at 3k plus 1k for axles.
Just make the power first then see what brakes.
Some guys get good life out of the old 4l60's just depends on you right foot. So if your right foot can blow or save components why bother upgrading until you actually know you have to.
The real question is what type of driving are you doing? If your doing spirited mountain driving or doing track days then yes upgraded brakes are an absolute must but if it’s just a cruiser that’s only going to see a decently hard brake pedal application once or twice per drive upgraded brakes are actually wasted money.
