Apart from a roller cam a bottom ends job is to only hold together , I'm fairly sure most if not everyone in this thread knows the power is in the breathing capabilities.
Put a roller cam , the same compression , the same rpm possible rotating assembly at a similar weight and some aluminium heads to run a similar dynamic compression ratio that flow a similar CFM and an intake that can handle it it'll do it.
Whether it's a 302,304,305,307,308 if you're flowing the same CFM through the heads and intake with the same cam profiles the air pump doesn't care who casted the block....
It's simply the fact he's on a budget something you never seem to understand and the budget won't include CNC ported c.o.m.e ally heads , tie bar lifter roller set up and a good intake manifold plus adding a minimum of 700ccs of capacity to get even LS1 numbers.....
