Bypass SRS
lil_mickey
LOUD AND PROUD
33
Geelong; Victoria
VH 253 :-)
Lol bet this one gets some attention so before you read this keep in mind...
The car in question
WILL NEVER BE ON THE ROAD AGAIN!!!
Ok, so I have a good mate with a 97 VT exec paddock basher. we set the airbags off by accident (through a ditch) and the light came on and starts beeping... Decided to remove the Airbag, seat belts and srs computer...
Pulled the computer apart to see what was inside(as 1 would) and wrecked it
The car dosn't like us now:whistling
All I want to know is what sort of signal does the BCM get from the SRS and is there a way to emulate the srs? we don't want to spend the money on a new computer and airbag but want to get rid of the error...
Now remember that
THIS CAR WILL NOT BE ON PUBLIC ROADS AGAIN
Thanx in advance
accentstencil
68
Eschol Park, Sydney
WH II Caprice, 5.7 2018 Equinox LTZ V
You can't get rid of the error without a Tech 2 or similar scan tool.
lil_mickey
LOUD AND PROUD
33
Geelong; Victoria
VH 253 :-)
but even if the error is removed, is there a way to disable it?
ausrs
64
00 SS M6/79 chev Monza
pull the globe ?
davway
Warrnambool
WK LS1 Statesman
so the car wont run (or run properly) because the airbag system has been deployed and hasnt been 'reset' - is that correct?
lil_mickey
LOUD AND PROUD
33
Geelong; Victoria
VH 253 :-)
correct:thumbsup
i thought about pulling the globe but the beep is annoying...
m8rkus
Maitland
VY Acclaim Wagon V6 3.8
SRS Airbag Bypass fix
I know it's a late reply, but you can unplug the airbags and put a resistor and capacitor in series on the plug, then clear the fault on the computer with software or scan tool etc... This will trick the SRS Module into thinking the Airbag is still plugged in, "DO NOT DO THIS ON A REGISTERED CAR IT"S ILLEGAL"
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Nice dig, but you apologized lol.
Did you read the bit that the SRS module is buggered? I dare say the car is in heaven now anyway.
