CAI mod done !!
pillzor
VS executive
but.... ive had too stick the breather piece down with silicone as there was not rivet holes as i was told there would be by claridge holden, this is only temp ofcourse .... cant see it causing any problems can it?
_R_J_K_
Zenki S14
You have to drill the rivet holes. Just make sure you don't use a bit that's to big, and be careful not to hit the radiator when you've drilled through the shroud.
pillzor
VS executive
yeh i seen that, i may not have too at this point tho because the silicone is holding rock solid.
camstatic
I'm back babeh.
Regional SA
VZ SS
I've just used short self-tapping screws with washers in the past.
pillzor
VS executive
im actually very suprised with the performance gain for such a small mod!
ephect
Donating Member
VS Acclaim V6
its one of the best mods, very cheap and easy :) its always good to hear members DIY, nice work
pillzor
VS executive
well with all the information provided on this forum ,,,, you just gotta do it yourself.
( not that CAI was difficult in anyway but damn it feels good too get it right!)
vsutespack
VS S Maual 5 Speed Ute
Did mine the other night and also did a memcalchange all for 200 bucks with a high flow panel filter. The ute goes hard now
