Yes you can. So long as you use an oil flush and drop the oil while its still warm (not hot) also be sure to change the oil filter at the same time. If you just did a swap without changing the filter or doing a flush it will still be okay but the viscosity will be higher due to the old oil but still quite thin So I would recommend doing these things. Question tho, what on earth brings you to wanting to put such a thin oil into a Commodore I believe its only the really new cars that require such a thin oil. An ecotec may even smoke due to oil blow-by
