very debatable, that is. i wouldn't be concerned about reducing the life from 80 years to only 15? personally i would not do it from a security point of view. also there are only 2 wires to disconnect if you need to remove the box if the amp is not mounted on it. its more work to remove the amp and all, power wires are free so the fuse needs to be removed, rcas can otuch each other causing problems in the h/u (blowing the ground track right?).azzfox said:the vibration will reduce its life by heaps
been there done that, not fun. exept the caus was a dodgy wiring harnessgarfa said:(blowing the ground track right?).
