Car Immobilised - Contact Dealer X
Dr_Mutley
South Adelaide
VE Calais
Hi all
I got the dreaded Contact Dealer message above and car won’t attempt to start. I assume the car is immobilised.
How the occurred:
Hadn’t started the car in a month and the battery was dead. So I put my spare battery in the boot and contacted it in parallel with the battery. Car started first go and I reversed it out of garage and let it run for 10mins. When I disconnected my spare battery, the car died immediately, as the original battery must have been completely dead (it fails and won’t charge on my charger). Radio will not turn on either. Fuel gauge appears not to work and says “Very Low Fuel” on dash.
I reconnected my spare battery again and the system start up check says stability control off, and the “Contact Dealer X”. The care seems immobilised and won’t crank.
Things I have tried:
- installed brand new battery
- checked fuses
- pulled the ECU fuse above the battery
- connected my spare battery to the front of the car
- disconnected the battery for a few days
So gurus! Any further ideas than the ECU being fooked?!
krusing
Melbourne, Bayside
Personally, I would of removed the dead battery, and charged it externally,
And placed the good battery in till the other is battery is charged, that's if I was able to be charged.
Could you have revered the terminals in error ?
I think the only option first is to disconnect the replacement battery overnight, if you have not done that,
otherwise, you will have to get it scanned, to see where the error's lies,
however with my experience with the VE Immobiliser system and Keys, being a RFID system.
I am tipping your car has forgotten your Key some how.
Have you got a spare Key to try ?, if so, see if it does the same thing,
If it does, there is more to it, and a scan would be in order to see what it is doing, well in this case, what its not doing.
Without a location of where you are located,
no members are able to direct you to a place that maybe able to assist,
or for any member maybe able to help you directly.
Dr_Mutley
South Adelaide
VE Calais
If it does, there is more to it, and a scan would be in order to see what is doing, well in this case, what its not doing.
battery polarity certainly not reversed. As stated it ran fine until disconnecting my spare battery. 2 keys, both do the same thing. Southern suburbs of Adelaide
krusing
Melbourne, Bayside
Hmm ok, just had to ask to establish the situation,
What is the actual voltage at the Battery ?, and at the on-screen mode via the steering wheel controls ?
I would say either the ECU/BMC and/or the RFID unit has gone to sleep,
Because it turns on to give you the warning,
Check all the connections in and around the battery, since you only disturbed that area.
As a matter of cause, maybe disconnect the ECU and BCM plugs, and re-seat them.
Otherwise you will need to get is scanned to see why the MIL has been activated, and will pin point the area of the fault.
lout
60
Langwarrin Victoria
when you connected the jumper battery did you connect at the post clamp or after the fusible links
maybe something is faulty in that area
07GTS
Australia
VEGTS BUILT BLOWN E85
check all fuses everywhere engine bay, boot and passenger kick panel just sounds like one is popped like comms or something
Dr_Mutley
South Adelaide
VE Calais
Thanks for the replies guys..,,
As per picture, battery connected in parallel in boot.... checked fuses at battery, L kick panel, and in engine bay, all seem ok....
lout
60
Langwarrin Victoria
what is the battery clamp to the right of your booster battery in pic 4
Dr_Mutley
South Adelaide
VE Calais
Hi mate. I only see four clamps in that picture. Two positive, and two negative. There is a black box to the right hand side of the picture which is a charging box for a dual battery (thumper) set up. It’s not currently connected so it’s not associated with this problem.
