Car Immobilised - Contact Dealer X
Dr_Mutley
South Adelaide
VE Calais
yeah back to normal after fixing the 60A fuseable link
Hi Dr Mutley, is your VE still going? I'm getting exact same warnings on my dash except while I was driving the 'reduced speed' warning msg came up. I pulled over and had a look under the bonnet, not that i know anything about whats under there, so jumped back in turned the key that's when the contact dealer msg came up and wont start. If anyone has any suggestions would be appreciated. Thanks
Jakesv608
Mount druitt
Ve sv6
I’m having similar problem disconnected and reconnected battery to try and reset air con now my car is immobilised accept my car won’t even switch over I don’t even get no dash light or sounds I only have the stupid red lock and car in the corner bloody putrid these ve commodores are absolute pieces of ****
Jakesv608
Mount druitt
Ve sv6
It’s like there is no power running through the car
Jimmymac72
51
Queensland
WN Caprice V8
CHeck the fuseable links on the positive battery terminal…. There’s 2…. Is one blown?
I’ve been having the same issue the last few months. It’s sporadic. Car will start then as drive a few feet shut off. Firstly I changed to a new battery. All good. Then did it again. So I did a scan, nothing. So disconnected battery for a short time and all good. Did a scan again nothing. But all good. Then today was out for an hour came home. Then piped out to pick up son and happened again. Same old thing working then stopped as reversing out. Did all things above and working again. Found your post so checked the 60a terminal
Fuse both fine. I’m absolutely stumped as to what can be causing it. I might just change the terminal fuse anyway just in case. Where did you get yours from? Cheers buddy
lout
60
Langwarrin Victoria
check the positive post on firewall hidden behind glovebox
lout
60
Langwarrin Victoria
remove the glovebox
it is up high behind the glovebox
