changed motor & wont start
naked racer
vl commodore
i just got a good running motor that started first time every time from a beat up vl and put it in my vl but now it wont start, i dont know what to do because it ran perfect in the old vl but as soon as i put it in mine it wont fire up? what do i need to look at replacing?
cheers
2DIE
ONEDOLLAHOLLA
South Aus
www.torn.com
97 Acclaim
Does it turn over? Is everything connected properly? Need more detail.
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
I would say you have either missed something plugging it all together or maybe a fuse has blown. Double check EVERYTHING.
FstStig
Diagnostician
Central Coast, NSW
2010 VE SV6
Could of just missed something like an earth or connected the leads up wrong on the dizzy (I'm assuming the VL's have a Dizzy?)
naked racer
vl commodore
it turns over but wont start and i think the ecu is giving me false codes here are the codes its showing. 11, 12, 14, 21, 23, 24, 31, 32,
but i know theres nothing wrong with the starter motor or air flow meter because they are both brand new
detox_nath83
Another VL Driver
Queensland(Sunny Coast)
VL Turbo Commo
Reset the ECU and run a diagnostic again..
are u getting fuel?? Hoses arnt on wrong?? as in return is on the inlet
are u getting spark?
Process of elimination
CAS failing???
naked racer
vl commodore
im getting my vl back 2night so i will have a look in the morning
jatsvl
NEEDS MORE POWER!
vl exec wagon
it is bound to be a minor oversight E.G some connection somewhere as has been suggested above.
the motor swap was auto to auto, manual to auto or vise versa? it maybe a wire loom or neutral safety switch problem.
nasty1
adelaide
vy2 clubsport
i was thinking was auto to manual....
bit more info?
naked racer
vl commodore
it was auto to auto
i didnt end up getting my car back home lastnight so i cant do anything yet but hopefuly getting it back 2nite or 2morro morning
