lorax
- Feb 6, 2012
- 2
- 2
- 0
- Location
- Newcastle, NSW
- VTII Aclaim Wagon
Cabin environment control cluster bulbs
The GM part number for the replacement bulb unit is GM-92142572. This is for the green bulb. You can also get a clear bulb.
From Jaycar an appropriate replacement bulb would be the Car Alarm Switch Replacement Globe BI Pin. You would have to desolder the blown bulb, remove it from the holder and then solder this one in.
Here are some pictures of the bulb unit required.
The 2 metal tabs come into contact with tracks on the printed circuit board when the bulb unit is twisted into position. I can't see these tabs on the "Neo Wedge" units you are looking at. Perhaps you can ask the seller. You can also ask what size the different units are (i.e T3/T4/T5). The base of the bulb holder required is approximately 10mm in diameter.
Here is another website that offers different coloured instrument LED kits: LED Bulbs suitable replacements for Dash/Instrument Lighting
Good luck.
Good luck.
