check powertrain error when gear changing
$heepy
adelaide hills
vz tonner
just wondering what could be the problem with a vz alloytech 4 speed.
the problem im having seems to be when in normal mode on the gear selector when revving hard (6000rpm +-) between gear changes it will throw up the check powertrain error light and will run roughly until you can get a chance to get off the road turn it off and start again. once cycled off and on it will run fine until you are overtaking or revving the engine hard again.
if you have the car in power mode it hasnt done this yet.
the trans oil is full on the dipstick albeit a bit brown, but definately not burnt badly or anything.
has anyone had this problem before? all my google seaching comes up with other errors which cause the check powertrain to come up but nothing specifically relating to this problem.
thanks.
$heepy
adelaide hills
vz tonner
nah havent scanned it yet,, i will have access to a scanner sometime next week, just wondering whether anyone has had this problem before though
hotrod
Banned
victoria
commodore s2
when checking the stick level the car most have been driving for 20 min then you check it while still running , when was the last time the trans filter got replaced. called be a solenoid to
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
I assume you are selecting the gears manually on an auto box and manging it in each gear?
May I suggest may be you're overdoing the revving ( 6000+ rpm!!) between gear changes, on I assume a standard engine and gear box?
Infuri
Hey sheepy, I am having the exact problem on my 2006 SVZ. If I rev the car in neutral, the error does not show, but if the revs go above 2.5-3k, the check powertrain light comes on and the car has a really rough idle. Have you had yours checked yet?
Towcar
Auckland NZ
VX Berlina Wagon
thanks.
Brown is bad.
commodore665
expat Saffa
54
New Zealand via Cape Town
2005 SV6 & Alfa Romeo 156 V6
Get it serviced , and don't rev it so hard , @ 6000 rpm no wonder it's flashing check power train .
Sent from my iPhone using Tapatalk 2
99notout
VZ Equip Wagon
You are 500rpm over redline and the ecu knows it and will usually through a code, you are probably getting fuel starvation, you are also making your bands slip, causing another code. Jeez it isn't Bathurst, wind it back a notch before your up for $$$
