SSSoooo
- Sep 20, 2023
- 7
- 0
- 1
- Age
- 19
- Location
- WA
- 06 vz ute 190kw manual
Hi i have been having problems with my 2006 VZ V6 ute (manual) 72,000ks
I bought the car a few months ago, previous owner did sparkplugs, coilpack, service.. but the car would shake hard at idle and sounded like it had a slight miss randomly the check powertrain would pop up and make it run like crap i believe it goes into limp mode until i turn it off and restart. The codes P0300, 301,303,305. Clear them run ok for a random amount of time before happening again.
i did injectors, fuelfilter, looked for anything obvious and checked sparkplugs to find that there was a rubber sparkplug socket grabber stuck on the plug Got it off made a tiny difference in idle but still shakey. And intermittent problem with check powertrain kept popping up.
Recently turning key to on and waiting for system check it popped up with "service vehicle soon" no crank until i unlock/lock doors. Until the red hand dissapears and starts fine. Threw a "P1632 immobiliser fuel disable signal recieved" .. possible slip ring failure?
I did a new oil pressure sender thinking that would fix service vehicle soon and possibly immobiler but nope..
Also today got a new key transponder thing and no difference :/
This ute is doing my head in. Has anyone had similar experiences and how did they fix. Hoping im not in for a new ECM
Thanks if you read this far cheerss
