CleaningThrottle Body VR V6
fitzy2005
Wide Bay, Queensland
VY S2 Berlina
your gasket for throttle body prolly stuffed, is your IAC valve wiring reconnected?
pyro_104
VR Executive
Note - if you have a strut brace like mine - removing the throttle body on a VR seems almost impossible without removing the brace. It obscures the removal of one of the nuts using a spanner - and the thread coming out the end is long enough to prevent you getting a socket on to the nut. I had to settle for a good scrub without removal.
lennyr
42
Wollongong
VR Executive S2
I just had the throttle body opened to removed the restrictor plate. Stupid I didn't have cleaner with me, will have to do some other time.
PS: what do you think about removing restricter plate. I've done it to increase power, worked alright.
G
Gooblies
Guest
Anyone have problems removing that plenum thing that detachs the throttle body to the inlet manifold?
On me vn v6 series 1 I had alot of problems with thermostat housing locking itself in with that stupid plenum thinga
Ended up smashing the old thermo housing out, then magically after a few bangs n shakes getting them back in.
That was prolly the hardest part when I put new head gaskets in
bricky
VR executive
ok i just did mine (vr executive ) and i am having trouble putting the springs bac in. i tryed once and when i touch the accelerator and there is no resistance. the lightest touch and the pedal is all the way down. not good if ur on the road. can somebody please explain how to put the sping back on cos i need to get to work next week. (without crashing)
VEARGH
"Stop,Drop..KaboOm.*
Penrith.
v_R
you can undo the strut brace quite easily, i just finished cleaning my throttle body, was full of **** but didnt really feel a difference..
pen15
mathew
sutherland shire
Commodore vr
if u guys are sydney based go to justjap (justcrap) and get yourself an oil catch can and mount it up like mine (new car pics up soon) off the break res bracket if you get to justjap go straight to the specials bin and pick 1 up for $20 with everything you need and never have to clean it again
hayesanator
vs equipe
hey i have a problem i just replaced my stock throttle body with a bored out one an there seemed to be no problems in removal an instalation but when i get in the car the engine light stays on an when i put my foot down it doesnt rev straight away help please!!!
