Skylarking
- Feb 3, 2018
- 10,221
- 10,784
- 113
- Age
- 123
- Location
- Downunder
- Commodore Motorsport Edition
The comment about TTY bolts was just a throw away line.Which suspension bolts are TTI? I haven't read that in the manual.
But there are plenty of TTY bolts and nuts scattered throughout our commodores though you'd wrongly think that critical suspension bolts and nuts holding critical suspension bits to our car would be uber strong and wouldn't be TTY... Yet the manual says that the sway bar bush insulator clamp nuts are single use nuts and must be discarded upon removal with new nuts fitted. Same for rear upper and rear lower control arm to knuckle retaining nuts and the trailing arm to knuckle retaining nut which are all a discard on removal items according to the manual.
And as you know, the bolts/nuts holding the drive shaft coupling are also single use item and must be tossed on removal (though these parts aren't suspension related,).
We do have the curse of TTY bolts & nuts scattered throughout our vehicle as it makes manufacture easier at the expense of increasing maintenance costs
