Clutch fluid is always dirty!
vr304
Auckland, New Zealand
2007 ssv manual
Yip it’s something that’s bugged me a little with my manual ss but clutch is working the way it should so all good
glennho
60
PERTH ,Darch WA
2006 VE SS -1977 HX Premier,2012 Hilux 4x4
Mines the same, ive changed the fluid a couple times but goes black again.
gtrboyy
vt ss & lc gtr
Only dreamed of those damn bleeder kits since they first came out!!!!
Never had gearbox out of either ls daily drivers that I've had nor access to car hoist long enough to do job.
If I had bleeder kit,reservoir etc would be bought before the clutch decision...vy models absolutely suck trying to get to bleeder nozzle when fitted with extractors/twin 3' exhausts/car on jackstands in driveway.
bb_zetec
QLD
2016 VFII SV6 Sportwagon Slipstream Blue Black Ed.
I've changed mine twice in the last 5000ks and it goes black quick too
vr304
2007 ssv manual
Probably needs a larger tank for the clutch fluid but the clutch works exactly the way it should so not a big deal
07GTS
Australia
VEGTS BUILT BLOWN E85
i just got that mal wood reservoir looks good bout double the size, more fluid it always good
vr304
2007 ssv manual
So this thread got me thinking about doing my clutch fluid since it had been 3-4 years, I didn’t do it the traditional way I used a syringe and sucked the dirty fluid out of the reservoir and, wiped it out and underneath the cap with a clean cloth, refilled it with clean fluid and cycled the clutch thru a fair few times until the fluid was going dark again from the rest of the dirty fluid in the system and syringed it out refilled with clean fluid etc etc for a few times till it was all clean again and I actually did notice an improvement in the clutch
BlackVXGTS
Melbourne, SE
That's fantastic thinking. I might use the same method with my brake fluid - would be a lot easier and faster than bleeding the brakes. Why hasn't someone thought of that?
chrisp
Melbourne Victoria
VF2 MY16 SS Redline Sportwagon
Brake lines are much longer than clutch lines so it might not work with brakes
vr304
2007 ssv manual
Yea I tend to agree, you’d be there forever trying to get all the old fluid out and even then you’d probably never get all of it
