Coolant Change
Exidor
I come in peace.
Earth. For now....
Used Martian spacecraft
My Aloytec is nearly due for a coolant change.
Can any body give me some pointers on this
procedure.
I am particularly interested in draining the block.
I know where the drain plugs are but what if any
problems will I encounter?
Are there replacable seals for the plugs, are the
knock sensors going to be a problem etc.?
Also what is the correct way to bleed air from
this particular motor.
Any feedback will be appreciated.:thumbsup:
andyman
The Only 6sp VZ Wagon
Orange, NSW
2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
honestly, ive the coolent still looks pretty normal, just get the genuine holden coolent, remove the bottom hose, drain all that, stick the hose back on and fill her back up with coolent,
unless the coolent is major contaminated, there isnt much need or advantage to what you wanna do
Exidor
I come in peace.
Earth. For now....
Its probably the way Holden performs a
coolant change anyway.:rolleyes:
However, because its every five years
I just wanted to do it properly.
PaulSV6
CHE Tuned 156.8rwkw
Castle Hill
VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
Then again 5 yrs seems along time between coolant changes, ive always done a coolant change every 2-3yrs.
Considering Coolant does go off after time.
Torquative
Sports Economy
VE SV6 3.6L SIDI 6sp
I was lucky being ex police car from the rural part of NSW my coolant was green when I got it at 90 000 kays, so had obviously been changed at some point as Holden is red.
Ive just been draining/bleeding it from the radiator, filling it up and letting the fresh stuff run coming into the hotter months, but yeh apparantly the genuine stuff is supposed to last 5 years or something
Escape-The-Fate
HSV, i just want one
Gold Coast
VE SS, M6
you can do a full radiator flush if you want..its pretty easy, with the engine cool and everything take off the top and bottom pipes..let all the coolant run out and then stick the garden hose with water running into the top radiator hole..until it runs clear through the bottom and if your really keen get underneath and do a reverse flush by doing the same thing with the bottom radiator hole, stick the hoses top and bottom back on..then fill it back up with coolant..i got the red stuff that holden recomends from autobarn for the old vt..bottle of it was $80 tho
you can buy proper radiator cleaning stuff but not necissary unless really filthy
andyman
Orange, NSW
take how you like, but you wont flush the motor properly unless you take the thermostat out,
as i said, unless the coolent is discoloured or rusty (which it shouldnt be in an alloy system) there is no realy advantage, just reverse flush the radiator and fill it back up,
if you are going to change brand of coolent, id remove the thermostat and flush yes, as you shouldnt mix coolents
Exidor
I come in peace.
Earth. For now....
I wanted to open the block taps to drain any tap water.
I suppose it is unecessary to fill with dimineralised water
only?
Escape-The-Fate
Gold Coast
VE SS, M6
thats only for the battery im pretty sure..normal water has always worked for me
