Yeah it sounds plausible and that may indeed be the case but based on what? These bolts are definitely TTA according to the Holden VF workshop manual PDF page 2824 of 11631 which states the following:
12. Remove the brake caliper to knuckle mounting bolts (2) and discard.
Note: The brake caliper to knuckle mounting bolts are single-use, and must be replaced whenever they are removed.
- Install the brake caliper (3) to the steering knuckle (1).
Caution: Refer to Fastener Caution.
Note: Do not use an impact wrench to tighten the brake caliper to steering knuckle mounting bolts (2). Failure to comply may cause damage to the brake caliper to steering knuckle mounting bolts (2)
- Install the NEW brake caliper anchor plate to front steering knuckle mounting bolts (2) and tighten to 40 N.m +90 degrees (30 lb ft +90 degrees).
Maybe it’s more than simply cleaning a bolt and adding loctite, just sayin
