Diff into HQ?
vkwalks39
NUCKING FUTS
Stawell Vic
VK V8 / VH V8 / VR V8
Gday guys, My old man has a Holden HQ sedan. He wants to change the diff. Cause now, he wants disc brakes instead of drums. He wants to know if he can put a diff out off a vr-vs commodore into the Hq? Your help would much appreciated :beer chug: Cheers Jason
Darcon666
Evil is always around you
At home
www.gfy.com
Your Mother
No, would be my first guess... well not without some major modifications(To the diff & car rear end...) :D
vkwalks39
NUCKING FUTS
Stawell Vic
Cool, We are going to give a go! finger cross it might work lol thanks for your help mate...Cheers Jason
Clutchy
Wild west of Melb
vz wagon
cant ya just find a hz disk rear end or something as id say the commodore diff will need alot of work to fit.
GothicKidd
ლ(ಠ益ಠლ
South Australia
VR S2 Exec
I thought you could easily upgrade to disk brakes from the old Drums..
vkwalks39
NUCKING FUTS
Stawell Vic
Gday guys, i think hq diff with disc brakes are hard to find, aren't they? So I though a commodore diff would be a better option cause there are so many of them. How much is ti to change drums to disc? Jason
GothicKidd
ლ(ಠ益ಠლ
South Australia
VR S2 Exec
Could find a place that works on brakes, and ask about it? Im not sure..
Reaper
Tells it like it is.
RG Z71 Colorado, 120 Prado , VDJ200, Vantage
As above - go raid the rear end out of a disk braked HX - WB and swap it across. The master cyl/proportioning valve will also be different from memory but it's a worth while upgrade. You may need the diff housing itself out of a wagon or 1 toner as HQ had leaf springs on the rear (can't remember that for sure though).
Reaper
vkwalks39
NUCKING FUTS
Stawell Vic
Thanks guys for advice, could we just change the brakes housing from drums to disc, it's a V8 diff, ratio is 3.36 he wants to keep it but change the brakes setup......... Cheers Jason
383 hatch
42
Cowes, Phillip Island
Reaper
HQ sedan (and wagon) ran 4 link and coil springs. Ute, van and 1 tonner ran leaf springs.
Yes, you can bolt the disc brake set up straight onto the existing diff, however you will need to change either the wheel bearings or the complete axles as the wheel bearing is different on a disc brake set up. You can use the disc brake set up from any HX-WB (including statesman).
