In all seriousness, if you do wanna drift ya vx ya gunna need to...
.weight reduction without upsetting balance
.strut braces and subframe braces to stiffen er up and give er some more "feel"
.Extractors and straight through exhaust, no mufflers or cats...but not too big...
.don't run a airfilter, just a bit of pipe off the tb down to the front bumper.
.remove ac and everything that goes with it.
.New shocks/strut inserts and some Fe2 springs front and peddlers sportrider lows in the rear
. The most expensive tyres you can afford front AND rear, and not too low a profile, a set of 18s with 235/40s work well.
.bigger swaybars, but not too big because you actually want grip, that way you can enter faster
Don't worry too much about power, its not power that makes you drift, it certainly does help though and your definetely not going to be able to hold angle for as long as a more powerful car or link corners or make bulk smoke,,, however you still will be able to drift like a sick Kent!!!!
----500rwhp corn juiced & boosted ls1----
