[QLD] Dual outlets on vt v6 performance
JSTCOZ
SE Queensland
2000 VT S-Pack II
quick question, couldn't find my answer anywhere.
Stock V6 VT with exhaust outlet on each side, both pipes being 2.5 inch and left exhaust outlet going around fuel tank.
Will this setup lower the performance because it has two 2.5" pipes instead of the sinlge i have at the moment?
thanks alot
:beer chug:
DLFHUB666
GIT 'EERRR DONE!!!
37
Nhulunbuy NT
VX SS, PX Ford Ranger XLS Dual cab
i reckon twin 2.5" would be to big for a n/a 6, just do what soop said.
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
It probably won't do anything at all apart from change the look. You have the exhaust exiting out of one 2 1/2" pipe already, adding another won't make it flow any better or worse. The exhaust will take the shortest route out the back anyway, most of the gas will exit the LHS pipe as it is almost straight. Very little will go around the corner and come out the RH pipe.
This is assuming you are just splitting the exhaust at the back and running two pipes.
