So I performed the splice after 2 odd years of procrastinating and persisting with erratic performance. Always cylinder 2 misfire. 300 and 302 codes every time this happened.
I could manage the vehicle by backing off and or changing down to 3 when the going got tough and revving it out a bit. Then it felt like it would clear out somewhat and run smooth - just right on the edge of throwing the codes again. Mostly noticeable at idle and slowly adding load to the engine in top gear when converter is locked, towing, AC ect.
Then on the weekend it finally just stayed. Threw the codes and wouldn't go away. Rough idle all the time very erratic all pointing to cyl 2.
Performed the splice to cylinder 2 to cyl 1 and took a little while to clear out and begin running smoothly and idling smooth but definite improvements. But the powertrain error and engine light wont go away. I have cleared the code and it disappears but comes on next engine start. Has anyone had this after a splice or could it be another issue?
Also drove around for a bit with my diag tool connected to laptop and notice o2 sensors on each bank a little strange. I would have thought they would read fairly similar but bank 1 is reading around .83 volts and bank 2 less than .1 at idle. Pic attached if anyone has any ideas.
If anyone would like to see data of any other sensor to help diagnose (if you can be bothered) let me know.
Anyway apart from the powertrain light the car seems to be running heaps better thanks for the help so far.
Edit - have already changed the plugs and coils before doing the splice.
I was getting the same fault with injector 1. There was no fault with the circuit. Once I replaced the cats (there’s a thread on my woes with the issue) all the faults, glitches, performance probs went away. Tests on the cats checked out ok, they weren’t.In reference to 60HOM's diagnosis steps in 2013; Probably stupid question but i'm confused what is faulty here in this statement below? Would i need to replace the injector in this case? "If the miss moves then your coil pack is faulty, if it stays then and the spark plugs are good then its your inj which means your ecu has dropped out that inj due to a possible short from that coil pack.". Also, if possibly the coil pack has shorted then does that mean coil pack is faulty or or we talking about the wiring to it's plug?
Actually i have Cylinder 2 down and the ODB2 error is "P0202 Cylinder 2 - Injector Circuit Problem", troubleshooting it now.
Since when is driving two injectors off one signal a 'fix' for a problem? A temporary band-aid to get you out of trouble... sure, but doing this creates so many other problems with power/torque, exhaust emissions, cylinder/manifold wetting, misfires etc. The reason engineers designed sequential injection was to solve problems and improve design.you should be pointing out the misinformation
So since it was done, someone actually fixed the original problem and the patch up caused the problems to continue.
Love the feedback. Great knowledge to share with others
