Sam_100
- Oct 26, 2005
- 218
- 112
- 43
- VFII SV6
Hi guys, I posted this on an existing thread so not sure it's got much exposure so trying again for some feedback. The car on two occasions has thrown up a P0300-00 error code. Each time I have cleared and everything seem fine.
First time was driving the car, engine light came on and the service ESP warning. I turned off the engine at the next set of lights, restarted the engine light turned off. I cleared the code with a scanner and haven't had any problems. The only thing I noticed was the down shift on the transmission felt harder. The second time was this morning when I started it using remote start. The engine turned on but was not running smoothly and turned itself off. I started the engine again, connected the scanner and it had the same fault code - P0300-00. It didn't seem to run well at this time until I cleared the code. The car also hesitates on take off sometimes. This has all happened just after I changed the spark plugs.
After clearing the code, the misfire count on the scanner for the cylinders is 0. The only thing the scanner has thrown up in addition to the code is the following. I assume this can be discounted as the source of the misfire.
Also, the evaporative solenoid surge valve is very noisy when I turned it on through scanner. You can hear it on this video near the end -
- It's making a ticking noise.
Edit - Forgot to mention the scanner is picking up a malfunction. see attached picture.
Is the noise it is making normal? Could this be causing the misfires?
Any other areas that I could look? I might need to replace all the spark plugs.
Regards.
Regards.
