Mon-aro
- Feb 4, 2023
- 266
- 55
- 28
- Location
- Australia NSW Southern Highlands
- VF Wagon, VF ute
Hi guys here i have 2009 SV6 LLT timing chains was replaced about 500ks ago, every now and then the car throws p0420 so i clear it straight away, the other day was driving along the high ways and the car went nuts! shaking along with loss of power and low power mode msg engine lights flashing unburned fuel etc… Luckily i had my scanner with me so did a scan and came up misfire codes P0300 P0301 P0303, cleared the codes and kept driving and suddenly car went back to normal.
Monitored the car for awhile and still good apart from p0420 which comes every couple days or so. Today was driving the car and got low power mode msg and engine light flashing, Codes logged are P0089 P0300 P301 along with a thick white smoke and unburned fuel smell.
Now i know the codes are all from the same bank which B1 driver side and i know they are all runs through connector, I plugged the scanner to read some data please have a look at the photos below. the question is Is it loose connector? What should i look for? any of you guys had the same issue? Any suggestions? would be great! TIA
