Engine Scanning....
AmericanGuyInAUte
52
Ute VS
Hey!
I have 2 scanners here but can't get any live data (or even codes) on it. Both of my scanners are for OBD2 systems. I'm guessing that the ECU in the 1997 VS Ute (V6) is not an OBD system.
What do i need to scan this vehicle?
Lex
Geelong Victoria
VT Executive S1 V6 6 speed Auto Wagon
Hey!
ALDL
Here's what l use.
losh1971
North Tas
VE Series I SS Ute
AED by Envyous Customs and a laptop is what I used to use.
jeepster
WA
VSII Ute
Ideally, you need a Tech1. But they would show up on eBay once a year at most. You may see Tech2 clones that work with ALDL, but they wouldn't support a VS, only later models. The Vident partly works with VS. If your ute is manual with no ABS or airbags, it would be okay for you.
  • Like
Reactions: Lex
