jeepster
I replaced the exhaust oxygen sensors recently, and it runs worse. Also the exhaust is black with soot. So I put a Vident scan tool on it. Error codes are 76 and 78, meaning the trim differs too much left versus right. Then look at exhaust sensor readout. One is zero volts and the other is 1.05 volts. 1.05 means much richer than stoichiometric ratio. So presumably the PCM is pumping out more fuel trying to correct the zero volts, and eventually gives up setting error codes. But the other side with high voltage. it should be reducing fuel, and the voltage should come down. Any ideas what could be wrong? First I suspected the zero volt side was unplugged, but had a look, connector is firmly together.
