I've committed to respraying the rest of the car. I ended up fitting front and rear bars after spraying them along with the side skirts. There are just too many panels to blend through and there are plenty of carpark dents I'd like to fix too. As it was, it looked like a patchwork quilt.
Spray booth booked for this coming Saturday, so I've put some pressure on myself to get it all prepped before then.
Ended up fitting the 3.73 diff today along with the 3" Xforce exhaust. Sounds good at idle and under load, but does drone a bit at light load up a slight hill. Diff is quiet and has done wonders for performance too. Going to borrow Sandman's Tech2 to correct the speedo shortly.
Had some serious troubles removing this trim - it ended up coming off in tiny pieces. I have a replacement for it anyway - the chrome was damaged. I've removed a few at pick a part before but never had this sort of trouble...
Very roughly primed after removing sikaflex with wire wheel. Surface imperfections will be hidden by the trim anyway so wasnt too fussy with it.
Filling a couple of small imperfections in the guard
Primed guard
3" exhaust and new diff fitted. This exhaust is destined for the senator - I'll find something a little more sensible for this.
