Oops hit the submit button dam glide pads
It does not matter what the capacity of the engine be it 5L or 1.5L if it makes 500hp it will consume 750CFM of air on the inlet side and this air needs to exit so exhaust gas flow will be the same as well.
As I mentioned before it does not matter whether the exhaust goes through the TC or wasegate as long as it can exit for the desired HP rating
I agree with both points
- I just figured that the small housings are used so that when the 1.5 litre is *not* making big power, the turbo can still have razor sharp response. - whereas with a larger motor (or a supercharged small motor 'emulating' a larger motor) this same kind of response can be had with a larger housing.
as for top end flow, I see how the gasses can flow either through the wastegate or the turbo - Although wouldn't it be more efficient to let them flow through the housing?
I read somewhere that the compressor needs a certain amount of energy to make it produce boost in the intake.
so now lets say you have two of the same sized compressors, and a huge and tiny rear for them both... they both need the same (or close enough) amount of energy extracted from the exhaust gasses to achieve the boost we want on the compressor side.
Now I read that smaller exhaust housing will require the exhaust gas to be under more pressure in order to extract the same amount of energy as a larger housing would, with less pressure.
I.e. larger housing allows more flow, so less pressure in the exhaust required to get the same amount of energy through, and vice-versa. - having said this, the more pre-turbo pressure the quicker the spool up, and the more mass flow through the turbo, the more potential energy can be extracted to drive the compressor.
Hopefully I'm making some kind of sense so far
ok, since the wastegate is controlled by the *intake* side of the engine, it will set the exhaust pressure to whatever it needs to be in order to maintain the desired boost level on the intake, regardless of how big the gate is. (although of course if your gate is too small to vent all the 'waste' exhaust gas, boost creep will ensue)
Some pressure in the exhaust is fine - but in my opinion too much pressure will cost power and lead to a 'more dangerous/closer to detonation threshold' running engine.
So applying the above ^^ theory to the example you have given with the T76:
- The .5 AR rear would require more pressure in the exhaust manifold than a 1.0 AR rear in order to make the same amount of boost. - Regardless of how big the gate is.
- The 1.0 AR would spool later than the 0.5 AR, due to the lack of exhaust pressure excerting torque on the turbine wheel.
- The 1.0 AR can potentially harness more energy to drive the compressor.
Another thing to note would be exhaust flow - most tubular turbo manifolds have a nice merge collector going into the turbo exhaust inlet - the gate is at an angle etc and doesn't lend itsself to good flow (although usually the exhaust is under pressure anyway so this doesn't effect boost control) - I have seen some interesting setups running a wastegate OFF the actual turbine housing! - I'm beginning to see why!
At the end of the day - it's a work of art to balance all these things nicely, to create an engine that suits it's intended purpose as best it can!- and therein lies all the fun!
I presume your approach, warrjon, is to drive the supercharger at a decent overdrive ratio, and as such, the turbo won't have to work very hard in order to achieve the total required boost once compounded? - If this is the case, a small rear housing would work nicely, as you won't need to extract much energy to drive the compressor, and hence the exhaust pressure won't need to be very high.
I would imagine this kind of setup will produce very quick full boost, and give a very flat torque curve throughout the rev range, however, at the sacrifice of sheer top end power... but regardless, this would make an awesome street car!
I've gone with the approach of having the supercharger cranked right up for great and responsive low end, and to spool a turbo with a big exhaust housing quickly. Once the turbo gets happy, I switch off the charger, and let the fully spooled turbo with it's big exhaust housing take care of business up the top. The idea is to use each method of forced induction at the point where it works most efficiently - and take full advantage of them both.... while somehow switching gracefully between them somewhere in the middle
- but i do intend on experimenting with a few things which might make me change my approach!
^ Anyway, wow, what an essay! I might have gotten a bit carried away with that post.
