H
harrop.senator
Guest
Fronts are 180-230 lbs/inch
Rears 360-440 lbs/inch
Couldn't find the fe2 to compare.
I can't find the away bar sizes for a vz sv6 if your V8 is an ss it should have a 27mm front. 16mm rear.
The hsv fronts are a 28mm and so is the vz Monaro. Price of those probably more then an aftermarket sway bar though.
Vt V8 fe2 is 17mm so can be a cheap upgrade if you can find one.
Sorry I wasn't that helpful , without the vz sway bar sizes and the fe2 spring rates it's hard to do a good comparison.
