VP_Luke said:
i wonder what will happen in a little while when those pots get dirty and start contacting/non contacting when they shouldnt :s
does this system include things to stop you from hurting the car? i.e. cold start, foot to the floor, won't rev high? etc?
For VP_LUKE and anyone else who is interested or wishes to add their thoughts:
Yes, the VZ Alloytech:
* still will not start up with WOT (as with Ecotec)
* is rev-limited to a shade over 4000rpm in Park or Neutral (on the auto, not sure about manual)
* if you have any throttle opening whilst changing between reverse and drive it will momentarily drop the revs back to idle to relieve strain on the driveline/transmission
* will reduce throttle (torque) input if brake and accelerator are pressed simultaneously (eg, when trying to "stall up" for a quick launch)
* low speed throttle inputs (eg, parking, reversing a trailer) are a little lumpy due to the throttle lag
Overall when jumping from my wife's VT into my VZ, the VZ has a much more responsive feel, and requires a lot less pedal travel to get it going. This is mostly due to the variable "ratio" of input provided by the ECU, whereas the VT has a more linear behaviour as the throttle body and the pedal have a direct link. Obviously the increased responsiveness in the VZ is also in part due to higher power output and a flatter torque curve, but this is more relevant to situations where heavy acceleration is used.
In response to your other point, fly-by-wire throttle is not new in the automotive industry (on a global scale), so I am not anticipating there will be many issues with failures on VZ's and future models. Like many electrical components they will probably require periodical checking and replacement before they start to fail.
