_R_J_K_
- Dec 20, 2008
- 6,723
- 1,856
- 113
- Zenki S14
It's not super unreasonable - as you go wider the wheel sticks out more with the same offset, so the offset needs to go higher to have the same amount of poke - play around with some exaggerated sizes on Will They Fit, you will see how width and offset are relative to each other and that you can't have one without the other. +43 would roughly put the face of an 8.5" wide wheel in the same place as the 8". They might be playing the safer fitment given you can't roll the spats. Having said that, all the figures you're quoting are pretty conservative in fitment terms, so it shouldn't be an issue really.I still think the 40 something offset from Tempe was a bit suss. They must have been thinking non IRS.
If you're buying the wheels through Tempe it will be pretty obvious if there's issues if you test fit them there. Then you can just test fit something else if you want them.
