- Apr 15, 2006
- 22,638
- 20,532
- 113
- Location
- Sth Auck, NZ
- HSV VS Senator, VX Calais II L67
I did read the whole thing.....
I still don't agree that a SSL spring is "softer" than a standard spring especially on a standard non-progressive rate spring. One a progressive rate coil one end is softer but it's compressed as soon as the car is lowered to it's ride height (have a look under you car at the suspension strut and the top couple of coils will already be sitting atop one another) Once the vehicle is sitting at it's normal ride height (for the SSL spring) the spring rate from that point onwards will be harder, if it wasn't then the spring wouldn't be able to arrest the vehicle weight (with the reduced suspension travel) when it hit's a bump and the suspension would bottom out.
Not all lowered springs are progressive rate, in fact not many are, even factory fitted springs generally aren't progressive rate springs. Generally to increase spring rates, you can increase the coil diameter (but is usually limited to vehicle specifications) or the coil wire diameter and/or the number of coils. The quality of the steel used is also an influence, this we agree up on.
Free length doesn't confuse people, it's important because when suspension is at maximum extension the spring must remain captured, this is critical for the safe performance of said suspension.
I'm not trying to confuse anybody. But trying to simplify a statement with info that is somewhat miss-leading is wrong. That's how Internet folklore is born.
