Daniel Buggy
- Aug 5, 2018
- 12
- 0
- 1
- Age
- 24
- Location
- Sydney
- Holden commodore VX
Not sure sorry mate, how do i check
Thanks mate will do download the app and try it outthere is an iphone app called fuelly. when you fill up you give it odo, cost and ltrs. it works the rest out for you and tells you how your car is running. you can also manage multiple cars
Probably from the gauge problem but I also feel like it drinks a lot of fuel, but at the same time I’m not sure how either of them happenIs it really su cking a lot of juice or does it just seem like it cos of the well known gauge problem?
The gauge is only showing the information it gets from the sender in the tank, so if the sender is stuffed the reading will be wrong.Probably from the gauge problem but I also feel like it drinks a lot of fuel, but at the same time I’m not sure how either of them happen
Closed loop operation, doesn't have anything to do with coolant temp.That is incorrect. modern EFI systems go into closed loop mode fairly quickly to reduce emissions, in the case of the ecotec engine I believe the threshold to go into closed loop operation is that the engine coolant has reached a minimum of 30° C and the engine has been running for 60 or 90 seconds (and obviously it's getting the correct signal from the O2 sensors).
